Hi. This is my first year opening my salt water pool (12x24:10,000 gallons of water). There is plenty of algae in the pool; pretty much coating my whole floor. I opened it today and I'm currently just cycling the water (not filtering it through the earth filter) and I've added 2lbs of shock.
Questions:
1) Is there any issue with adding the salt bags now? It can only help since it's needed by the system to create chlorine, correct? Or is there a reason why I should hold off on this?
2) Will I actually see the floor clear up (the green go away) as the algae is getting killed by the chlorine/shock? Or will the shock just kill the algae, but then I have to vacuum the floor to get rid of that green?
Any additional advice would be greatly appreciated!
Thanks in advance!
Questions:
Thanks in advance!
