- Jun 21, 2019
- 129
- Vinyl
- Intex Krystal Clear
Hello everyone
This year it has been a little warmer and I opened the pool around the same time of year as usual, but as a result there was some green around the edge ring of the water. It is also ptetty cloudy.
My question is should I open it as normal and run a chemical test first or do I attack algae with high doses of chlorine?
So far what I have done is brushed the walls (especially were the green was present) I've been running the pump/filter for 12 hours (still running), and have been running the pool cleaner vacuum as well.
I know this is probably an obvious question but don't want to waste $ throwing chlorine at it if that isn't the first step Thanks in advance
