- Feb 14, 2022
- 39
- Vinyl
- Hayward Aqua Rite (T-15)
We bought the house in September 2018 and closed the pool a couple weeks later (NJ). For the next 3 years we had someone come and open, close and service the pool weekly we were entirely hands off. The first two years were great, crystal clear water even at opening. Last year we seemed to be getting a lot more sediment on the bottom of the pool, and some algae which he treated weekly. Overall it was still pretty good, but not crystal clear like previous years. When he closed it last winter he did not vacuum it and it had a ton of leaves in it. Because of these things, and my original "We'll hire a pool company for a year so I can see what they do and then take it over myself" which went from one to two to three years, I decided it was time to do it myself this year. Bought my TF-Pro Salt test kit, some new equipment including an Active 30 robot, and waited for spring.
This was my opening last spring, which was similar to the two before it.
This was my opening yesterday
We set Marty the robot in to do his thing. I started the manual vac to get the pile of worms before the robot hit it, but as soon as I started the robot, he ran straight for the worm pile and turned it into worm dust. I worked brushing and vacuuming while the robot did its thing, and the nice clear, but green bottomed pool turned into this.
Brushed a few more times, backwashed the filter a few times, started balancing the water. It has 0 chlorine and < 30 CYA when I checked it a month ago, and same thing yesterday. Added 7 of the 9.1lbs of recommended cya into two suspended skimmer socks, one in the skimmer and one in front of a return and half a bottle of chlorine, set the pump to run at 100% 24/7 and restarted the robot again before going to sleep.
Got up this morning to this much improved scene,
Chlorine was gone, cya is up to around 50 now, added the other half of the bottle. Going to give it another brush after work while the robot keeps scrubbing all day and then I'll have to start the SLAM. This is my solution for hanging a sock of cya in front of a return without it resting on the liner.
