- Aug 20, 2020
- 6,044
- Plaster
- CircuPool RJ-60
Ok, maybe follow above advice on suction side air leak. Pool stores carry a line called “pool lube”. I’m not sure if Vaseline is a good idea or not.But I've tried two hoses and two different vacuums.. Also ran the water through the return, into the hose, and watched it come out freely so the hose appears fine. My pressure drops to 0 and you can hear the pump loses prime.. I get barely any suction at all.
