Hey everyone-
I went to open our pool, myself for the first time(likely a bad idea).
Removed all the pipe stands, water level high enough, installed all the drain plugs (filter and heater. Put water into the pump, went to kick on the breaker to start the pump and all it does is hummm. It hums for a little bit and then stops. About 3-5 minutes later it starts humming again.
This pump motor is not that old, previous owner had the motor replaced on it few years ago.
What could be causing this? Is it motor having issues? Is this a capacitor?
Guess i'm trying to understand what needs to be done to get this pump running.
Thanks for your help in advance everyone.
It's a Pentair 1hp, Whisperflow
