So I finally got all the gunk and debris vacuumed out of my pool, and then tested the water with the TF-100 test kit. My results were:
FC=0
CC=0
TC=0
TA=90
pH=7.5
CYA=0
From what I've read in pool school, I need to get my CYA up before I get the chlorine levels right. I plugged my numbers in the pool math calculator, and it said to add 161oz of stabilizer. Am I doing this correctly? Should I be aiming for shock FC of 12? Is the sock that the stabilizer goes in a regular sock that you wear?
FC=0
CC=0
TC=0
TA=90
pH=7.5
CYA=0
