Hi, I just opened today (unfortunately - learned that lesson) to a pool that has medium brown debris flakes similar to what was on the top of the winter cover. Algae? Dirt? I wonder if it went through. Water is pretty clear, with possibly green tint towards the bottom but I can't tell. Hooking up the pump tomorrow and wondering what my process should be as I've never opened to bad water before. I closed to TFP perfection last year. Time to replace the 2 year old winter cover too?
- First, vacuum out debris on bottom, brush sides, cove, and bottom, so no visible debris is seen
- Test water (Taylor K2005) for everything
- Fix pH to 7.2-7.5
- Immediately add CYA via sock method to 40
Do I need to SLAM for sure, or if it's dirt, can I just vacuum it up and add Chlorine to target levels?
- While that's dissolving, immediately add liquid chlorine to SLAM level/target level?, knowing it will take DAYS to get CYA dissolves and up to 40
- After 3 criteria are passed, balance alkalinity if needed
Can anyone advise on this approach or tell me what to change or if SLAM is definitely needed? Thanks in advance - Pics are increasingly magnified, with 'clean spots' I brushed on the bottom.
Kristin
- Fix pH to 7.2-7.5
Kristin
