I have an open terminal bulb. AL14 style bulb. The first bulb held 15 years and now I'm replacing the bulb every year or so. Since the terminals are open in the back and I'm replacing the bulb in the water I'm wondering if that is contributing to the failure of the bulb? There is no housing on the back of the bulb, just a housing in the pool shell. The terminals are open and sit in the water that is in the housing of the pool shell. There is a gasket, although I'm not sure what it's purpose is if there is water behing the bulb anyway. The cover of the bulb is held in place with 3 screws. Once I replace the bulb it does work for while. I'm confused on how it is working with water behind the bulb on the terminals. It seams that every post/video etc I could find shows that the bulb has it's own water proof housing and then this get placed into the housing on of the pool shell. Yet my bulb has no housing and the open terminals sit in the water.
Was mine built incorrectly? What gives? Do I need to replace this style of bulb when there's no water in the pool?
I'm hoping there someone else out there who has this same style of bulb. Thanks.
