- May 8, 2018
- 337
- Plaster
- Hayward Aqua Rite (T-15)
It's been (almost) a year since I put this product on the deck and my COVID-19 isolation project of the weekend was to move all of the furniture, plants, etc... off the deck and give the area a good clean and put down some more sealant for the summer. Just thought I'd give a quick review of the results so far.
No big surprises. There was some mildew/dirt that didn't want to just hose off, but it neither did it seem to be tenacious enough to get out a pressure washer. So I made up a weak solution of bleach and laundry detergent and gave it a light scrub to get the funk out of the nooks and crannies, which worked fine. In a few places I had some iron stains (plant stands that will NOT be put there for the winter again) which I had to get after with more aggressive methods, but they mostly came out. I had about a gallon of the mixed product left after finishing up last year, so I transferred it to a paint can and sealed it up with the hopes that I could use it to touch up. Opened the can up and gave it a good mix and it seemed to be fine; I touched up my spots and it dried normally and still matched the original color. The website says it will last for 3 weeks in a sealed container- I went a good bit beyond that! I then re-sealed it with the same sealant. I don't know that I really NEEDED to do this, but since I had done some touch-ups (and I'm climbing the walls with boredom), and it didn't seem to be as hydrophobic as it was in the first months, I went ahead with it.
I think that if I were more diligent about hosing off the surfaces regularly, I wouldn't have needed to do that scrub. And I'll be getting some small tiles or pavers to put under the feet of anything iron that sits on the deck.
In summary, it held up really well. The cracks in the deck that it filled are still invisible- the only place where there are cracks are at the seams where the caulking shrunk a little bit, and that was kind of expected. The color I used was very light, but it doesn't appear to have faded much or at all over the year. So far, I'm still pleased with it; Here's to another year (albeit, a year that is promising to be challenging).
www.troublefreepool.com
Concrete Deck Coatings; Opinions, facts, personal experiences sought!
Hi, all... I'm in the process of making improvements to a pool (and house) I've had for less than a year. The cement deck was originally (from the 1980's documents provided) coated with Kool-Deck but I am pretty sure that this coating was gone over multiple times with one or more other...
