- Sep 28, 2016
- 56
- Vinyl
- Pentair Intellichlor IC-40
1st time pool closing by myself and I am in the middle of blowing out my main drain with a pancake air compressor set at 25psi. I have 2 main drains and when i continuously blow out with compressor, one main drain bubbles continuously very strong and the other main drain intermittently bubbles. Regardless, while main drain bubbling I closed the main drain valve to air lock and immediately shut off the compressor. My main concern is if i properly blew the main drain with the air compressor.
I also tried to put antifreeze directly into the suction plumbing but I did not see the antifreeze come out of the main drain. I did see the antifreeze when i blew out the skimmers though.
