- May 3, 2014
- 62,852
- Fiberglass
- Pentair Intellichlor IC-40
That is pH. Low pH.Started at 68 but the results were the same even down to 40. Hands dried out and cracked really fast.
7.4 is low? I don't think so. My pH at the time ranged between 7.2 (a bit low) and 7.8. The effects were the same throughout the range. I am pretty sure dry and cracking skin is a known side effect of chlorine.That is pH. Low pH.
I have sensitive skin to start with so I t thought I'd share my experience. High chlorine pool water is more drying than tap water to me.I’ve regularly been in both our hot tub and our pool at a FC level of 16 (SLAM level for CYA 40) and experienced no ill effects. In the pool your can’t even tell there is chlorine. The hot tub usually has some CC which you can smell but I’ve not experienced any side effects other than that. During the winter when we already get dry skin soaking in the hot water for a few hours does dry out your skin a bit, but for hours of soaking in hot water this is to be expected.
As for why I regularly do this if we have a hot tub or pool party I always take the FC to SLAM levels to ensure the FC stays in the pool/tub throughout the duration.
If just “dipping your hands in” is drying out your skin something else is happening. It’s not due to a high level of FC appropriately matched with a suitable level of CYA.
For sanitization, yes. See the link I posted above, chlorinated isocyanurates are a strong eye irritant.Back to "high" chlorine levels... the point, as explained in the chlorine/ cya link that Marty left, is that the absolute level of FC is not particularly meaningful without knowing the CYA level. You can safely and without irritation swim with FC levels well above 10 if your CYA is high enough. It is the active chlorine that matters.
FC of 3 with no CYA is harsher than FC of 12 with CYA of 50.
@Flying Tivochlorinated isocyanurates are a strong eye irritant.
The pool store at that time.CYA of 68?
How did you measure that?
Oops, never mind, I didn't see the person you mentioned.
CYA of 68?
They have a very accurate photometer, which now that I have my K2006 kit and I can see that I misread the scale, it matches. They now read 40 and the kit reads about 35-40 (hard to tell because Taylor's scale seems logarithmic).So then you have no idea what the actual CYA measured then.
Pool stores get the CYA test wrong more times than not.
Your skin condition is what is setting you up for cracking, not the chlorine. You can blame all chemicals in a pool, but that is not the underlying problem. Please consult with your Dermatologist.I am pretty sure dry and cracking skin is a known side effect of chlorine.
If I understand you correctly then swim just don't get water in your eyes?Here is a nice table. All forms of asociated cyanurates tend to be acidic. It does not really matter much since the additions are usually
by dissolving so its a gradual lowering of the ph.
if you intend to rub your eyes with any for of associated cyanurates you will most likely result in a chemical burn.
The normal pH range for eye tear is 6.5 to 7.6; the mean value was 7.0.
Even though SWG pools like a PH of around 7.8-8, i try to keep mine around 7.4 for comfort.
Im lucky to have a high fill TA so adding acid is a no brainer.
View attachment 356058Chlorinated Cyanurates: Review of Water Chemistry and Associated Drinking Water Implications - PMC
Since 1958, cyanuric acid and two chlorinated cyanurates, commonly referred to as dichlor (anhydrous sodium dichloroisocyanurate or sodium dichloroisocyanurate dihydrate) or trichlor (trichloroisocyanuric acid), have been added to outdoor swimming ...www.ncbi.nlm.nih.gov
I can swim in my pool with the eyes open all day long. Could't tell you about yours or anybody else's.If I understand you correctly then swim just don't get water in your eyes?
