- May 26, 2023
- 6
- Plaster
- Hayward Aqua Rite (T-15)
Just upgraded AquaLogic controller to the OmniPL. Everything is working great except I can’t figure out how to get my Polaris PB4-60 pump and pressure cleaner to activate within the relay settings in the OmniLogic panel. When setting up I’ve selected HVR1, and it won’t turn on. I’ve selected HVR3, and it won’t turn on. In the service mode, I’m able to get the booster pump to turn on when I turn on HVR1 AND HVR3, since you can select more than one relay at a time. On the old AquaLogic, the Polaris pump was running off of Aux1.
When you setup the cleaner, there’s no way to select two relays to turn on the booster pump, only one. What am I missing?
