- Sep 29, 2012
- 121
- Plaster
- Hayward Aqua Rite (T-15)
Hello,
Is it possible to write overlapping schedules using the Omni PL system? I want to run my pump 24 seven at a low RPM, but four times a day bump it up the RPM for 30 minutes at a time to increase circulation in the pool. My goal is to be able to have the pump returned back to the baseline 24 seven RPM after each 30 minute increase RPM circulation time. Can you overlap schedules in the system? The folks that installed my pool are worthless for technical support, and Hayward is even worse than that if you can imagine.
Thanks
Thanks
