Omnilogic retro fit upgrade and heater connection
rhulse1
3
Florida
Hayward Turbo Cell (T-CELL-5)
Hi Pool world. I recently installed a OmniPL retrofit kit from an old aqualogic system. Everything went good except im having trouble configuring the heater. The heater is a Pentair minimax nt 400 (yes very old) juice might not be worth the squeeze…lol I have attached pictures of the connection. The heater doesn’t fired when spa mode/filter/heater is turn on. However I can manually push the spa button on the heater and the heater with turn on. Please advise if the possibility exit for controlling with the omnilogic controller.
Does the heater start if you take the orange and blue wires off of LV1/LV2 HEATER and touch them together?
Have the pump running or this test.
Hello, l believe because of the angle of the picture it looks like it connected to both LV1 and LV2 however it’s only connected to the LV/1 section. Do you still want we to give it a try?
Yes. Those two wires run to your heater.
Be the relay and connect them together and see if the heater runs.
