Won't hurt a thing. Just add what tou need upon return. Give it 30 mins-1hour for disbursement.Cat said:Thanks Zea3, I'm sure I'll be heading to the Heebe soon, just down the street. I wasn't sure how much bleach to put in. I finally got the pH down to 7.2 this morning. Started yesterday, wasn't sure how much acid to add, so I would add some, wait a couple of hours, test and add more acid until I got the correct read. I have added 4 gals. of 10% chlorine, but how long until I can start testing the shock chlorine level? Right away, or do I have to wait 2 hours for proper disbursement?
What if I run out of bleach before I hit the shock FC and I have to run to the store, will that mess up the results? It would be about a 40 min. round trip for me.
Cat said:Brushpup - thanks for the encouragement. Maybe I was thinking CYA=cloudy, but maybe it's because of my CH that someone said would not allow my pool to clear up. It's at 880 and I can't partially drain right now. Is this correct or should I still keep slamming?
Smykowski said:Richard320 is our resident high CH expert, so hopefully he will be along shortly to chime in. Until then, I don't think CH of 880 and pH of 7.2 will cause cloudy water. I think it needs more filtering time - sand filters will take the longest to clear a cloudy pool, but they work just fine.
X2 Get ready to take advantage!Isaac-1 said:I know there is a drought going on, but I would suggest preparing for the rains, when they do come, perhaps go ahead and get a small cheap submersible pump of the kind that Harbor Freight sells for around $50, and some cheap blue tarps you can hang to funnel water into the pool, if you have gutters on your house you could even rig diversion hoses on them to the pool, although on those you would likely want to some type of filtration, at a minimum a pair of panty hose over the end to catch the larger chunks After all chances are the rain bearing fall and winter frontal systems are not that far off..
Ike
