Unit is a Raypak RP2100 Mfg date 6/1998- Propane unit. Dormant and uncovered for 10 years. No propane tanks on site but they were there once.
Unit powers on! Eureka!! - "SNS" code among others. She's coming alive again.
Step 1: Clear leaf debris/chipmunk nests/birds nest/sticks etc.
Step 2: Replaced Temp sensor (Amazon) Raypak 009577F - CLEARS "SNS" Code - Unit showing correct temperature of pool 68 deg
Step 3: Install (2) 100 Gallon Propane tanks (Professional install - used existing line) New regulators - 1 at tank and 1 at heater.
Unit is charged with propane - pilot sparking heard but will not ignite (ILO code) - I rattle the board and it fires right up! - Does a heavy flame rollout though. (Still have my eyebrows BONUS)
Step 4: Open board and find mouse nest I missed on it - they have chewed wires and loosened solder in one area
Step 5: Ordered replacement board off Ebay (Raypak P/N 601769) $140
Board arrives 1 week later.
Board works! No more codes - Unit fires up but flame is very orange/heavy (Dirt debris in the burners is my best guess hence the orange flame)
Step 6: Remove burner thanks to this youtube video help:
Burners were filthy! Spider webs, clogged, dust, dirt. Removed, wire brushed, vacuumed, Compressed air - Reconstructed and reinstalled - There was also a lot of water in the Gas valve itself which I blew out/vacuumed out at the same time. After reinstall -
SUCCESS!!!!! Works great - effecient blue flame, strong! - Takes pool from 69deg-84deg in 10 hours.
Then it stopped working again- Unit still fires - shows it's lit (flame icon) - pilot is lit
No Error Codes
Pilot is lit but flame is very weak - almost strobing from flames flickering because not all burners are lit
I removed the burner unit again to check all valves etc. Seem fine to me - looks fine. No glaring blockages
The only thing left to replace is the gas valve (Robertshaw-Grayson 7000 BDER-LP-67C)
I ordered one online (Exact replacement was $179 Hayward CHXVAL1934 IID Gas Valve LP 150-250 | eBay) and I will replace and repost here to see if it fixes problem.
What else could be wrong??
If anyone can shed some light on this issue and perhaps give me some guidance it would be very appreciated! Any way to measure gas pressure coming in off tanks? Correct PSI at the regulators? I'm all ears. Thank you!
No Error Codes
