I'm in the process of purchasing my grandparents house with an in ground pool with a vinyl liner circa 1975 ish. About 5 years ago, my grandfather closed/covered the pool because he didn't want to take care of it any more. Unfortunately, he passed away so I have very little knowledge of the pool's construction, age, last liner replacement...basically everything. I've also never owned a pool before. I'm getting a little overwhelmed and nervous that I made a huge mistake. In order to get some info about the pool, we decided to take the cover off to see what condition it was in. Basically, it had turned into a black swamp. The water was terribly black and thick at the bottom with sludge. The liner is pulling away from the track in multiple areas and the corners have come off. We wanted to clean it up a little before a township inspector condemned it and prepare for a liner replacement (which we knew wasn't going to be salvaged based on the ripping and everything) so we drained it. We had to shovel the bottom of the 8 foot deep end with a snow shovel to remove the last of the muck. This whole process took about a day/day in a half so it hasn't sat empty very long. The liner is already pulling away from the stairs and areas of the deep end walls. I'm not worried about salvaging the liner at this point just the structure of the pool itself. I can't quite tell what kind of pool structure it is---it almost looks like fiberglass but I know it wasn't a drop in type pool like the more modern day pools. There isn't a drain or any type of plugs in the bottom for pressure or draining. I'm putting some water back in it today---at least it is clean and clear for now---and having a pro come on Saturday morning (4 days away). Do I even bother continuing to get some water into it? If I plan on replacing the liner does it matter if water keeps pressure in the pool? Appreciate any help you can offer.
