The specific question is: do I need to shut off my Intelliflo pump to adjust a 3-port Jandy Never Lube valve?
In more detail: I finally figured out what this return piping is for (pictured). The right side is labeled "Spa Fountain" and should divert water to the port in the center of my spa floor, though I haven't tried it yet. The left is un-labeled, but I opened it and found it feeds two aerators in the pool. Up to now, I've been careful to turn off the Intelliflo pump before operating the 3-port diverters to switch the suction and return between Pool and Spa, based on what the previous owners said. But when it comes to this fountain/aerator piping, I'm not sure whether it's a bad idea to repeatedly shut the pump off and on trying to make minor adjustments to spray height. Is it a bad practice to adjust these valves while the pump is running? The majority of flow is still running to the returns in the pool and spa, so I can't see accidently creating a bad backflow situation.
