Hi Folks,
I have been using the Dichlor + Bleach method for 3.5 months now and I love it. It's so easy. I hardly ever have to adjust my PH and everything is so stable. It's great. I did add a mineral stick for "insurance" in case my FC drops too low. Here are my current numbers:
TA: 60 (drop 7 doesn't impact color)
PH: 7.5 and hardly ever moves.
CYA: 30
Calcium Hardness: 130
Borate: 50
So, assuming that's all OK, here is my question: why does every other reference I can find say that the TA goal should be between 80-120 and that anything below 80 will cause corrosion? This came to a head recently on a Bullfrog FB group where somebody posted offering to help people with chemical numbers and I asked the above question. His answer was that anything below 80 will cause corrosion. I talked about how, if TA and PH are stable, what is the problem? He wasn't able to give me an answer about what chemically would be going on to cause corrosion in my situation, other than "TA below 70 will cause corrosion". I said my water seems stable but he insisted that PH should move some from time to time and the fact mine is stable at 7.5 is a bad thing and shows my TA is too low.
I said, "so we're destined to throw baking soda or acid at our spas forever"? His answer; yes - it prevents the corrosive condition.
Can somebody explain to me the discrepancy between TFP's recommendations via the "how to use chlorine" thread and the numbers seen elsewhere? To top if off, I ordered a test kit from TF and the card in the kit even says TA of 80-120.
I just want to make sure i'm not "destroying my spa from the inside out" per that BF forum. I even helped a friend set up his spa using this method and want to make double sure...
Thank you.
CYA: 30
Borate: 50
Thank you.
