- May 3, 2007
- 16,980
- Plaster
- Hayward Aqua Rite (T-15)
Irrigation supply store may have it as well but there is another option that may work.
If you can run 2 - 2" pipes, one for the main drain and one for the skimmer, the effect is the same as a 2 1/2" pipe although probably a bit more expensive. This is actually a better option since you can put ball valves on each run and control the suction between lines. Can you get to the main drain separately or is it conected through the skimmer? If it is connect through the skimmer and you can get to it, you could break the connection, cap the skimmer side and connect one of the lines directly to the main drain.
Otherwise, you could just go with a single 2" line as that will provide most of the benefit.
