reggiehammond
- Oct 4, 2020
- 2,253
- Plaster
- CircuPool RJ-60 Plus
My reasoning for saying don't increase CYA is you continually find yourself under minimum FC requirements. When you're under minimum, organics can take off. You may have algae and you don't know it. Increasing CYA just makes the FC less effective if you find yourself low, and makes the SLAM process more expensive.
Why are you struggling to maintain FC at CYA 40? That's not normal.
I'm just worried you don't quite have the TFP basics down. Your FC should NEVER be below minimum and you seem to not quite understand the
FC/CYA Levels. Not trying to be too sharp, just want to help you avoid any larger problems.
