OB Queen Creek AZ
RoyR
280
Escondido/CA
Funny, I would move those plastic home depot chairs all over the pre-dig dirt...sit down and imagine the possible issues etc.
Check the setback from the rear fence (normally 5ft min)....I don’t know if that bond beam, will be in it...not even sure if you can put the equipment in there?
SKHart77
15
Queen creek AZ
It’s 6 feet from the back wall. Why wouldn’t we be able to put equipment there?
ajw22
16,416
Northern NJ
Anyone have any comments on Pentair vs Hayward for equipment?
Its Chevy vs. Ford. Pool builders seem to prefer Hayward. Pentair seems to be a bit higher in cost and quality.
It depends what specific equipment you are thinking of getting. Show us a list with model numbers.
QC Pool Dreams
45
Queen Creek, Az
Out of the 3 builders I had come through for quotes all 3 used Pentair and my friend in the pool cleaning/remodel business gave the same sentiment but Im sure for every Pentair recommendation you could find the opposite in favor of Hayward.
Are you guys going salt or no?
SKHart77
15
Queen creek AZ
Pool equipment:
Pentair IntelliFlo 3 HP pumpSKU: 011056
2​
Pentair Cartridge filter CCP520SKU: 160332
1​
Pentair Ultratemp(R) 140 H/C Almond Plastic High Performance Heat Pump; 140000 BTU (Heat)/80000 BTU (Cool); Digital Control; Titanium Tubing; 230 V; 1 PH; 60 HzSKU: 460958
1​
Paramount Series 2 Ultra UV 2-Lamp Water Sanitizer; 230 V-50/60 HzSKU: 004-422-2026-00
1​
Pentair 522043 Intellicenter Load Center; No Salt Chlorine Generator SupportSKU: 522043
1​
Pentair 521911 IntelliCenter i10P Single Body Personality KitSKU: 521911
1​
Pentair Intellicenter 522475Z Wi-Fi Antenna (primary client bridge)SKU: 522475Z
1​
Pentair CPVC 3-Way Valve, 2-2.5"SKU: 263026
1​
CMP 25677-430-000 Brilliant Wonders LED Waterfall 48" Sheer 6" Lip, WhiteSKU: 25677-430-000
1​
CMP 25677-900-000 Brilliant Wonders Smart Sync Universal LED Waterfall Control BoxSKU: 25677-900-000
1​
Pentair 580037 Niche Kit for ColorVision LED Light Bubbler, White Color RingSKU: 580037
2​
Pentair GloBrite Color LED 12v 100' Cord Pool LightSKU: 602055
2​
Intellibrite 5G Color LED 120v 26w 100' Cord Pool LightSKU: 601002
1​
Pentair 79206700 PVC Large Pool Niche For Concrete PoolsSKU: 79206700
1​
Pentair 263045 Valve Actuator, 180 deg.SKU: 263045
1​
Super-Pro 25555-001-000 Flush Mount Return Fitting - GreySKU: 25555-001-000
1​
Waterway Plastics 540-6707 Volleyball/Umbrella Pole Holder Assembly 1.5 Inch PipeGraySKU: 540-6707
1​
Super-Pro, 25504-009-000 Water Leveler, Tan 1",1-1/2",2" HoleSKU: 25504-009-000
1​
Waterway Renegade Venturi IG Skimmer - Gray With Beige LidSKU: 540-5307-9B
1​
Paramount PV3 Nozzle with Nozzle Caps; Light GraySKU: 004-627-5060-08
1​
Paramount PV3 Ribbed Body with Cap, Light GraySKU: 004-627-4760-08
1​
Paramount 004-552-5452-00 PCC Step Nozzle Tool; PlasticSKU: 004-552-5452-00
1​
Paramount 6-Port Water Valve; 2" BlackSKU: 004-302-4184-03
1​
Paramount 004-203-0010-08 BuzzTop Channel Drain For Sump; Light GraySKU: 004-203-0010-08
1​
Paramount SDX2 High Flow Concrete Safety Drain; Light Gray, 2 PiecesSKU: 004-162-2231-08
1​
Pentair 100W TRANSFORMERSKU: 619962
1​
ajw22
16,416
Northern NJ
I think you will be better off with the simpler VS 011058 pump then the VSF pump proposed. There is no practical use for the variable flow feature. @Jimrahbe thoughts?
Skip the UV system and save some money. We see no need for a UV system on an outdoor pool.
Use the money saved and add an Intellichlor SWG at least 2X your pool gallons. How did you intend to chlorinate the pool?
Change the IntelliCenter to include the SWG.
Jimrahbe
17,106
Bedford, TX
SK,
TFP never suggests that anyone use a Variable Flow pump... They are just not needed.. The 011056 is a VS and VF which just makes it more complicated to use than it needs to be.. I suggest you use the 011028 which is a normal VS pump.. Not a big deal either way, but that is what I would do.
The one main downside to a VF pump is that as the filter gets full, the pump speed will increase to keep the flow the same.. What you really want is for the flow to decrease to let you know that the filter is dirty.. Yes the filter has a pressure gauge, but it is often out of sight and out of mind. Simple is almost always better.. :)
I think you are making a serious mistake not getting the IntelliCenter with the included SWCG (Saltwater Chlorine Generator).. Saltwater pools are the easiest possible types of pools to maintain.
Having an ozone system is just a waste of money unless it is for an indoor pool...
I am not a fan of in floor cleaning systems, but you see a lot of them in AZ.. I would want to make sure that the system is plumbed so that the IFCS can be shut off or turned on.. Even if the system works perfectly when new, there might be a time when it is down for maintenance and you want it off.. Many IFCS are integrated into the pool so that you can't run the pool by itself. Again, simple is almost always better and the IFCS makes a pool about 10 x more complex to repair than a standard pool.
I think you will have to have several more light transformers, as I believe you will need one for each light that you want to individually control.. I would ask your PB just to make sure.
Reactions: Arizonarob
SKHart77
15
Queen creek AZ
Thanks everyone! I’ll look into the difference between the pumps however on the SWG I have natural stone pavers (marble) and I’m worried about them corroding over time. I also really don’t like the feeling is salt water on my skin after I get out of the pool, it makes me feel flaky 😂. I was looking at getting chlorine injection however to make it easier to maintain. If someone has some ideas on the flakiness and maybe a sealant for the natural stone then I’m all in!
