Been cloudy and sub 75 all week. Have swg at 10% and FC keeps climbing 1-2ppm every few days. Is it normal
Not to have any burn off as fall begins?
You rang? I get panicky if I do the OTO test and does not come back with an Orange color.The OTO / block FC test is great once you get a handle on the FC relatively stable. Check @JJ_Tex avatar. Taxicab yellow is 8 to 10, then the orange starts and bright orange like his pic is 10 to 13 where it starts getting fluorescent orange. After that it gets darker and more solid orange on its way to brown at 20.
I'd be happy to let mine float at 8-15 but it I can't get a PH reading with anything over 10Cl...Yup. You've likely had a little burnoff and simply made more than you lost. Be careful about turning it down after cloudy days or the sunny days will have you turning it right back up. You can drive yourself nuts mocromanaging so instead, look at it as 'enough FC', or 'not enough FC'. I step in and pull the plug at a teen, if I happen to notice. I've lost count how many times it was a deep teen.![]()
Try 4 or even 3 drops. I usually have luck getting back on the scale that way. With 5 drops it's lavender.I'd be happy to let mine float at 8-15 but it I can't get a PH reading with anything over 10Cl...
Don’t jinx it - your a/c needs a break!Hoping that is the case, oddly cloudly and cold way too early round here.![]()
