Hello all,
I'm just finishing up a new construction pool/spa and am not happy with the pressure from the spa jets. I have discussed this with my builder and it seems he has no ideas on how to increase the pressure. I have the 3hp intelliflo pump, 6 jets, the plumbing to the spa is 2" and the plumbing run from equipment pad to spa is about 70 feet. The spa is a venturi design with no spa blower. I run the pump at 3250rpm when in use and the filter is clean so these are not an issue. My idea is to put in a bypass between the pump and filter. Would this increase pressure since there would be less head loss not having to go through the filter? Not sure if this would work. Any other ideas on what could be done to increase the pressure?
