-The only other possibility is that there is some blockage in that line. Has this problem always occurred since the pool/spa was built? The line may never have been cleared properly after construction.
That’s why I wanted to change the suction line, could be something in there so I want to start fresh with new drain line.
I was referring to the return line, not the suction line. The suction line is definitely a problem but I also believe there is a problem on the return side of the pump as well. As I mentioned previously, my predictions are for a lower filter pressure (due to high head loss on the suction side) but you are experience the opposite which indicates higher than expect return head loss.
Any idea how to clean the line ? I can try that as well
Remove all the jet fittings and nozzles. Run the pump and flush the lines.
So my question is , how I can see good movement in each return at the pool while it’s sending the same amount of water to the spa and I barely feel it ?
Because the problem is not on the pad but somewhere after the pipe splits to the spa. More than likely, the issue is with the replaced 2" line (as well as the suction line). The only solution may be to replace both at the same time. It is expensive to rip up concrete and expose those lines so you might as well do both.
Maybe the stupid builder did not plumbed the spa currently? I remember I see how they plumbed it and it looks like other spas , with the jet , air , loop etc...
That is what I am thinking as well. It could be the lines but it also could be the plumbing around the spa and to the jets. The entire plumbing might need to be replaced.
Sorry but I’m so lost here , could be bc the spa have 6 jets and the returns getting the water from its own dedicated lines for the pad ? And the spa have its own dedicated line and there is enough water going to the spa but bc ipits 6 jets I don’t feel it good ?
No, as I said before, the problem is likely after the pad equipment. The pool and spa only share pad equipment and if the pool is working ok, then it is likely nothing on the pad. The only thing left is the plumbing to/from the spa and the plumbing around the spa.
I can tell you one thing I tried , I plugged 2 or 3 of the spa returns and touched the other that I leave open and I felt a lot of water pressure coming out of the jet is that make sense ? Maybe that’s how we know it’s not clogged and we only need to provide more water by plumb is with 3” at lease I will have better flow when I’m in spa mode and less pressure when I’m in pool mode ? Is that makes sense?
That won't work because you are just forcing the water into the air lines. You cannot plug a spa jet that way. You actually have to plug the nozzle itself.
But again , let’s say I run at 3450 in pool mode , even if I close the pool returns and run the water back to the spa I can have 62 gym and still feel it very weak, I will have to try reduce the muzzle first and we will go from there.
Again, I don't think replacing the nozzle will help enough. The extra head loss is still there restricting the flow rate.
Another idea of simulation of the spa , I can easily access the pipe from the blower , maybe I can in addition to reducing the nuzzle , I can cut the pipe that goes to the blower , and I can add a loop , approximately 10’ from the spa and cap it for air , so I can control the air suction , that way I can get the effect of the jets , I hate to use the blower as it’s too loud and we can barely talk in the spa , any suggestions how I can avoid using the blower and suck the air manually ? Or you think I will not have enough air suction bc the spa water flow is not the best.
If designed properly, a spa does not require a blower. My spa does not have a blower and it works just fine. More than enough bubbles. The problem is that most PBs do not understand hydraulics very well as so we see a lot of spa jet problems here. Most of the time, it is due to plumbing that is too small for the spa jet flow rates as in your case.
But if you want to operate without the blower, just remove the blower from the pipe. But again, this will not help your situation much because of the excess head loss for the wet plumbing.
Do you have pictures of the spa when they were building it? With the exposed pipe?
A couple more questions for troubleshooting.
The VS pump should display, GPM and pump pressure. So please post GPM, pump pressure and filter pressure for the follow scenarios ALL at full speed:
Pool Only Mode
Spa Spillover Mode
Spa Only Mode
