- Apr 23, 2017
- 2,400
- Plaster
- Hayward Aqua Rite (T-15)
Ok so what should I do for the winter here in North Texas for my pool? I have read many posts about closing the pool for the winter but I'm not so sure I need to do this. Here are my questions thus far:
Should I turn off SWG for the winter an use chlorine?
Should I drop the pH to a lower level? During the summer my new pool seemed to want to stay between 7.8 and 8 so I would let it climb to 8.2 or so and drop down to around 7.4 and let it climb with aeration.
My automation system has freeze protection and turns the pump on automatically when temps fall so that is good. My PB said to turn the water features on at a trickle when a hard freeze is expected to keep water flowing thru the pipes???
Not sure what else I should or could do so any suggestions or tips would be appreciated. Here are some of my most recent numbers:
FC 8
CC 0
pH 7.8 or could be 8 (I always have a little trouble reading the colors )
TA 70
CH 400
CYA 80
Salt 3300
CSI -0.14
Temp 63
Lastly I run my pump from 9-11am and from 8-10pm. Is this good? Should I run from 9am to 1pm to ensure proper water turnover? My water is clear on current schedule...
Thanks in advance!!
FC 8
CC 0
TA 70
CH 400
CYA 80
Salt 3300
CSI -0.14
Temp 63
Thanks in advance!!
