- Feb 16, 2024
- 112
- Fiberglass
- Jandy Aquapure 1400
Is this PSI on my filter normal if running at low rpm (800)? I can feel water coming out of the returns
I run it for an hour at 2500rpm in the morning and 2500rpm for an hour in the evening. This time of year I have no debris and also have a skimmer robot. Salt cell is off because of water temp but it functions at 800rpm.Na,
Are your skimmers working at 800 rpm? How about your salt cell? If not, what is the point???
Jim R.
To add to this, I just checked it running at 2500rpm and it was at 10 psiI run it for an hour at 2500rpm in the morning and 2500rpm for an hour in the evening. This time of year I have no debris and also have a skimmer robot. Salt cell is off because of water temp but it functions at 800rpm.
Good to know. Sounds like everything is working as intendedMine is at 0 psi at 750 RPM.
2500 rpm is 10-11 psi on mine as well.
This should be approximately correct.I just checked it running at 2500rpm and it was at 10 psi
