Thank you. Test results.
FC -5
CC - 0.5
pH-7.2
TA -180
CYA - 30
CH - 275
Questions. On the alkalinity test when the color changes to red, should it appear to be a deep red or like a dark pink? if more of a pink then my TA is about 2-3 drops lower. I kept going until it darkened resembling more of what I consider red. Mind you, I have a photographers eye for colors.
I'm so glad its the weekend so I can do the OCLT test and then monitor how much chlorine is used up during the day as well. So far, I've done all my tests in the evening after work, once a day.
Thanks in advance for your responses. Happy weekend!
Ps. The only reading for pH is using thru k-1000 test? I'd say mine is between 7.2 and 7.5
Oh dear, I almost just took a swig of pool water accidentally.
