Hi Everyone,
I am new to pools and to this forum. As you can see from my signature I have the below equipment. I had the pool installed Saturday and having a hard time balancing things. I will explain what I have done below but basically trying to get my SWG to the right value where should it be?
Sunday - Filled pool and shocked it with Aqua Costal Shock Clorination, Added salt in the evening
Monday - Turned on SWG and set it to 5 (All levels where good except for calcium)
Tuesday - FCL was 0 set SWG to 15% added calcium (2800g), CYA (750g) Mursatt Stabilizer
Wednesday - FCL 1, CYA (20) left super chlorinate on all day value of FCL was still 1 so I added chlorine at 7pm and turned the SWG to 50%
Today (10am) - FCL is 10, CYA is 20 all the rest are ok (salt is 3400 up from 3200 the past 2 days), adjusted the SWG to 15% water temp is 82
What should I do to
1) Get the FCL down so my kids can swim
2) Adjust the SWG so it doesn't drop when the FCL drops
3) When should I adjust my CYA I read after a week
Thanks T
What should I do to
Thanks T
