SWGs are great for
maintaining your FC level. But they're not very good at
moving FC from one level to another. I always have a few gallons of liquid chlorine (LC) on hand just for that reason. Sometimes I'll need to goose the FC quickly, like right before or after a big pool party. The SWG can't really do that. Plus, while first figuring out the setting to use for an SWG, it goes a lot quicker if you have some LC on hand:
- Use the
FC/CYA Chart to determine your FC target
- Test FC at a specific time of day
- Use LC to bring the FC to your target
- Set pump runtime and SWG setting*
- Test the FC the next day at the same time
- If FC is high, decrease pump runtime and/or SWG setting
- If FC is low, use LC to bring the FC back up to your target and increase pump runtime and/or SWG setting
You keep repeating that process at the same time each day until your SWG maintains your FC. Without LC to restore your FC target each day, you'll be raising and lowering the SWG setting like crazy and it'll take way longer to finally find the right setting to maintain FC.
* If you fill in your signature with details of your pool (read the link below), so that we know your pool size and type of SWG, etc, we can help you ballpark the initial pump runtime and SWG settings, to get you started.
We'd like to give you a few basic pointers of items that will help us, help you. From filling out a signature to posting test results.
www.troublefreepool.com
