Noise from new pump
Welcome to TFP.
Check the water level in your skimmer.
Check your skimmer weir door is not sticking.
What does the pump display panel show when the pump groans every 30 seconds?
Is the pump connected to any automation?
Make a warranty claim with the installer. The noise is not normal.
Welcome to TFP.
Yes, it’s connect to OmniLogic automation panel. Nothing shows o. The panel when it happens but the PSI drops right down.
It almost sounds like it's power cycling.
If OmniLogic is put in service mode and the pump controlled from the pump panel itself, does the pump still do this?
It's new, so should be under warranty.
Who did you buy it from?
"Professional" or self installation?
What pump did this one replace and did the old pump ever make this noise?
Does the pump have a clear lid where you can see the water flow in the pump basket?
I think the pump has an internal problem causing the motor to stall.
You should make a warranty claim on the pump.
