My neighbor asked me to come take a look at this pool this morning as he was having some issues with weird flow. I hadn't seen his equipment setup before so when I first got there I asked him to cycle everything a few times so I could see how everything worked so I missed actually seeing what the starting point was for valve positions. The pool is about 2 years old and it looks like an Omnilogic controller (which I'm not familiar with) controlling to main GVA24 valves for suction and return. They have some other water features, etc but for the primarily loop is one VS pump and the two valves (suction and return). He also has the pop up cleaning jets.
Observations:
1. Neighbor says that up 1-2 days ago in pool mode and high speed everything seemed fine. The cleaner pop ups were up, spa was spilling over, and the skimmers had good flow. Today he was seeing weird issues with no/low skimmer flow and no spillover and the cleaners weren't popping up.
2. After asking him to cycle everything a few times and the valve positions seemed to line up with pool/pool in pool mode and spa/spa in spa mode with the exception of no spillover which is my main question.
3. In pool mode he told me he normally has flow to the spa and spillover. Today in pool mode the GVA24 for the spa return is closed off 100% and there's zero flow to the spa jets.
4. In a weird issue, after I had a chance to look at everything and walked back to my house he called me back with no skimmer flow. I came back over and the suction valve was in spa position though the controller said it was in pool mode. I had him switch back and forth a few times and it stayed reversed. It was definitely not reversed 15 minutes before and my buddy said he didn't mess with the switch on the valve. I reversed it with the switch and had him cycle it a few times and now it seems fine again but is weird behavior.
My main question is about the return valve position/programming. In order to get spillover he should have some flow to the spa jets but in pool mode the valve is closed 100%. I'm definitely sure my buddy didn't physically mess with the valve so I can rule out human error. Since I'm not familiar with the new controllers and the Omnilogic specifically my questions are:
1. Shouldn't the return valve be partially open to let flow into the spa jets in pool mode so that the spa circulates and spills over? Or is there some fancy check valve or pressure balance somewhere that I'm missing?
2. If its valve position, do the new controllers have some programming to handle this or is it done with the valve microswitch position?
3. If its just the valve and normal cam/microswitches for stop position like I'm familiar with then is this a common issue with the GVAs? I guess its possible it's been getting bad for a while and he just didn't notice as its been maintenance season until now but he swears the spillover flow seemed fine until a few days ago. If it is just the valve cam that needs adjustment/replacement what's typical split? Open 45 deg, 25 deg?
He usually does his own maintenance and doesn't have a regular pool guy. So I'd like to help him get it sorted short of having to figure out the controller programming.
Mike
Observations:
Mike
