Sandy,
A few things to check...
1. That pump uses a square O-ring that I hate.... Make sure it is well lubed and that it fits well..
2. With the power off, reach under the pump basket and feel inside the impeller area for leaves or other debris.
3. Put the filter MVP into the recirculate mode and see if the pump will prime. This mode by-passes the filter.
4. You could use a Drain King to force water backward from the pump into the skimmer, just to make sure that the skimmer line is not plugged.
5. If the pool is closed in the winter, make sure all the plugs are removed from the skimmer.
Jim R.
