Hello, I've looked all over and cannot find any solution to this problem so I'd appreciate any suggestions.
I have the Intex/Krystal filter pump as above, purchased new last year for an above ground pool. I just set up the pool for the season and the pump worked fine, and was running regularly for about a week. We had a number of bad rainstorms over the last few days (may or may not be related), and when I went to check the pump, there is no power at all.
All outlets are fine (I tested the pump with multiple outlets). I changed the GFCI plug to a new one but it made no difference (The old one seemed fine, dry, fuse was working etc).
I opened the whole thing up and there is no visible damage, no water, nothing fried. I tested the power with a multimeter and power is running from the plug to the circuit board. From there -- nothing. No red light indicator on the panel, no clicks, no hums, nothing. Just dead.
Beyond turning this in for the warranty (which may take months to get a replacement), is there anything I can do?
Thanks for any thoughts.
SS
SS
