Hope you guys are still with me...
I checked the voltage at the gas valve just now and I'm a bit confused. At ignition, I got 24v from across TR-TH, which is expected. However, after that, it got a little weird.
TR is jumpered over to point #1 and TH is jumpered over to point #2. When the switch is set to off, there's no continuity to 3 and 4. But when I flipped it to on, after jiggling it around a bit, I got continuity from 2 to 4. But here's the weird part - I never got anything from 1 to 3. Worse yet, there was continuity from 3 to 4.
Now, I don't know how this is supposed to work, but a typical relay I would expect would throw from 1->3 and 2->4. If that's the case, this thing is toast.
So, two questions:
1) Am I right about how this is supposed to work?
2) Can I bypass the (assumed faulty) on/off switch and take those spades and put them right on the appropriate TR/TH terminals on the left hand side?
