I'm getting ready to close my pool and realized my pump does not have any drain plugs.
I have a Hayward Turbo Flo II . You can see the two holes in the picture where drain plugs would normally go. I called Hayward and they said my pump shares the same plastic casing as the higher end models but doesn't have the holes tapped. I would have to tap the holes myself. I want to use a compressor to blow out my lines, should I just do it from the skimmer?
Thanks
Thanks
