We've had a couple of inches of rain this week which has really lowered the water temperature, but the pool is still crystal clear and inviting. I ordered a solar cover which should be here today, so hopefully I can get that temp up to a comfortable level.
This morning's numbers:
FC-- 4
pH-- 7.4
Water temp-- 75
Tomorrow I'll run all the tests and post my numbers. That will be the first time I've tested for CYA, so I'm curious to see that number. Based on the chlorine/CYA chart, I think I'll need to get my FC up to around 6 or 7 if my CYA is where I think it is. I'll add another 60 ounces of 8.25% bleach tonight which should do it.
Thanks to the guidance you guys have provided, it's actually been a fairly painless process. I attribute that to TFP-- specifically Pool School and the help and encouragement you guys have offered. Thank you.
