- May 23, 2015
- 25,727
- Plaster
- Pentair Intellichlor IC-60
Sorry, I thought this was an IntelliFlo.
For a plumbing system that is full of water, priming is unnecessary. That’s why I adjusted my settings to reduce it as much as possible. Priming a system really only refers to the process of pulling water into the pump and through the return lines when the system has been drained. Once the system is primed, it shouldn’t lose prime.
Pentair built some intelligence into their pumps to sense when the system has lost prime and to attempt to re-prime by jacking up the speed. They also built in a priming counter so that the system will make a certain number of attempts and then shutdown. The pump is also designed to shutdown if prime is not achieved in a given length of time. All of this is to keep the pump safe from burning out.
