I’ll reach out to Pentair, but they’ll probably give me the finger for self-install.Sean,
My CCP-520 looks the same, but not near as bad... It has been that way for about 6 years..
Since your pool is new, I would contact your pool builder or Pentair and see what they can do for you.. In theory it should be stainless steel and not rust, but I think there are rivets or spot welds that are causing the problem..
I never get a load of "stuff" like I see on your cartridges.. How does that get through your skimmers and the pump basket???
Pentair cartridge filter rusting inside
Hello, I have some issues with rust inside my cartridge filter. See pictures. Some background: Pool is about 3 years old. Located in a Houston suburb SWG ~25,000 gallons Using BBB from the beginning. Never had an algae [emoji3] Here are my typical chemistry ranges: PH is 7.6 - 8.0+ I am...www.troublefreepool.com
They might be willing to send you a new bottom tank under warranty.
Does a magnet stick to the metal?
If yes, how strongly?
I clean the skimmer baskets on days I use the pool, which is most. I get very, very little debris in the pool because of the autocover, and most of what does get in, doesn't end up in the skimmers -- it gets picked up by the robot. So I never vacuum. The pump basket never had more than a few pine needles or pieces of grass in it. at a time. Messing around with the pump basket lid didn't seem worth it.You should clean the skimmer basket daily and clean the pump basket after vacuuming at minimum. Your cartridge will last longer if you keep on top of this.
I have a sand filter and don't have to backwash as often if I keep the baskets clean. I would imagine the same holds true for cartridges.
Sean,
I did not even know the ring could be removed???
Does it just pull right out or ??? What did you have to do to remove the ring?
I do like the idea of trying a rust proof coating.
