Welcome to TFP! :wave: Once you load all your pool info into the APP, go the area called "Effects of Adding" and it will show you.
F/C still at 1 now CYA OVER 150. I added 1/2 bottle liquid chlorine 10% and ph increaser 24 hrs ago. Ran pump all night. I just want to get in with my baby granddaughters. Test kit is HTH multi purpose 6-way test strips. Btw I have berm keeping pool covered with a solar blanket to try to warm it up.....Now what?
Hello and welcome!
Unfortunately the test strips you are using are very unreliable. If you haven't added any CYA or any dichlor/trichlor then there's no way it went up from your last test, but it just shows how inaccurate test strips can be.
My recommendations are:
- Fill your signature in (see this link: Create Your Signature - Further Reading). Knowing what kind of pool, size, equipment, testing methodology, etc. you have are crucial for us to be able to offer advice for your situation.
- Get a decent test kit, either a Taylor K-2006c (the 'c' is important as it gives you more of the chemicals we often use) or a TFT-100. This will let you figure out what your CYA actually is.
If your CYA really is that high you'll need to exchange a lot of the water. How does the water look now?
