Add baking soda to raise TA to 60 ppm. That should raise the pH a bit.
Follow FC/CYA Chart. 2 ppm FC is too low.
2 FC was what I was told to add to begin with while the CYA gets distributed.
Add 30 ppm CYA via the sock method and 3 ppm FC worth of liquid chlorine.
Any ideas?4 days ago. I did the chlorine loss test; it dropped 1 point So I stopped the SLAM as recommended. I scrubbed the walls, ladder and vacuumed.
