I recently purchased a home and unfortunately none of the plumbing was labeled. I have been able to figure out most things through trial and error but I am stuck on one last issue. My pool has 4 inlet valves. One is the main, then skimmer, pool floor and spa floor. I then have my outlets into pool and spa. When I set to spa suction (or what I think is spa suction) and spa only outlets I still get over flow from my spa waterfall into the pool. Every suction setting I have tried leaves me with this over flow. My question is this normal and if not how do I stop it? In my mind I am just losing hot water into my pool when it could be staying in my spa making it heat quicker. I don't mind a little spill over but as it is now its basically the same amount of spill I get when the equipment is set to pool spa mode not just spa. Any advice would be greatly appreciated.
Cheers,
Derek
Cheers,
Derek
