My first pool has been up and running for just about a week now thanks to all the great help here! However, I have a few questions that I am hoping to get some help with:
When running my SWG and sand filter pump, I assume they have to run simultaneously if on a timer? For instance, the sand filter will only run when the filter is running correct? I set the timers on both of them at the same time for 6 hours per day, so they both come on about 8am everyday. My pool looks great, and I am pretty happy with my numbers for being such a newbie at all of this! I just want to make sure that I am running it correctly AND long enough.
I noticed some air inside of the sand pump leaf catcher debris basket (I think thats what its called!). Is that bad that there is air in there? If so, how do I get it out? I have dual outlet suctions that lead into that basket.
Backwashing.... I only backwashed once and thats when I first filled up the pool. How often should this be done. I honestly had no idea what backwashing was until I seen it on the boards here.
