I'm very grateful for the pool math app it has been extremely helpful.
Is there a way to extract test results and chemicas added so I can create a graph in excel of trends and effects?
DISCLAIMER:
I am extremely sensitive to chlorine so we are actually trying a Del ozone eclipse 20 unit for sanitation to keep chlorine levels lower. Except for when it is very hot or high bather load Del says we can run as low as .5 to 2ppm of chlorine. Levels around 2.5ppm or under don't bother me but my friends pool always gives me issues so so far so good. I just wanted to get that out of the way as I know it isn't popular around here. Pool has been crystal clear since we opened it April 29th.
In all other manners I have been following TFP method using 10% bleach, muratic acid, baking soda, and liquid stabilizer to balance chemicals. I am new at this.
I did a full round of testing after a storm and high load of debris in pool. Cleaned debris and vaccumed pool then tested.
1.6 FC
added enough chorine to bring up to 2.2
0 CC
7.4 PH
added muratic to drop to 6.8 as it has no trouble slowly climbing and it was recommended to drop TA
TA 120
is there a way to get lower TA other than lowering PH app doesn't tell me advice appreciated? Is this higher level ok?
CH 210
slowly raising from 130 last week
CYA 40
maybe 35 i'm still getting hang of dissappearing dot seems like voodoo reading chicken bones
TEMP 83
Cleaned my filter for the first time yesterday. I won't let it go so long every again. What I wasn't warned about was the smell. LOL! YIKES!
Just checking in to see if I am on the right track.
Any advice appreciated.
DISCLAIMER:
1.6 FC
0 CC
7.4 PH
TA 120
CH 210
CYA 40
TEMP 83
