Hi all
We moved into our property, about a month back....and it has a beautiful,good sized, concrete pool....a bit old one though. When we opened the cover the water was total brown we called the pool guys and they drained out all the water and did an acid and powerwash to the pool. it looked great after that and then we filled the pool. Yesterday the pool guys came in and started the pump and told us that only one skimmer is working (we have two skimmers for the pool). Also the heater and polaris pump are not working. The pool guys also added the liquid shock yesterday evening around 7pm and we took the water for testing today to a pool store.
The values are as below:
FAC - 0
TAC - 0
CH - 10
CYA - 0
TA - 60
pH - 7.6
COPPER - 0
IRON - 0
TDS - 196
Pho - 1000
We were asked to add the necessary minerals. which we bought
The main problem that i am facing now is
I tried vacuuming the pool with a manual vacuum head. The pool guy asked me to keep my DE filter setting to "waste" when i vaccum the pool so that the debris get out of the pool system. A few minutes into the vaccum i saw the water turning crystal clear green. I am able to see the floor on the deep end but the water color went from clear blue to green .
We added TA - alkalinity up - 16lbs as advised by the pool store water test report and the three 3" chorine tabs and also 3lbs of granular shock "chlor brite" we are supposed to add CYA in about 40mins (which is 4hrs after the TA) after the water turned green. what did we do wrong? or should i wait for the chemicals to do its job and wait.
Also the kids super eager to get into the pool. Is it ok to get in with the water color still crystal green or should i wait for the water to turn clear blue.
Please guide us. Thanks a lot in advance.
FAC - 0
TAC - 0
CH - 10
CYA - 0
TA - 60
pH - 7.6
COPPER - 0
IRON - 0
TDS - 196
Pho - 1000
