Hi! I cannot get a pic of my set up as I am under a tornado threat! Got to love Florida in the summer! But the pond is loving it!
JBF did the AWESOME pic with the labels. I wish I knew how to do that!
So I had my husband look at your hoses and he says that they all can be used with chlorine. The only real problem is what we are facing with not being able to stop the water......That can be fixed later when you drain the pool.
On to how to fix/clear the pool for now.......I am thinking about the skimmer/return. No good circulation and problems with filtering is leading to the cloudy.
Two ideas:
1. Find something that can be put in the skimmer and in the return to act as plugs at the pool. Not sure what to use but thinking large corks that taper, a tennis ball in the skimmer, ????? This will allow you to deep clean the filter sand.
2.Doing like Tom says. Skimmer hose to be used to take in the water at another level.
DE may help now. I hope you can find it at a good price.
Now comes what I am not 100% of but my husband says may be the problem. Your pump/filter/equipment is too far from your pool.That could be why your cleaner does not work. Just not enough suction.
Your circulation could also be a problem due to the return not having an adjustable eyeball so your water does not go around the pool to "push" it into the skimmer to go to the filter.
So you see---------no control of the pushing from the return and no sucking to the pump. All of that could equal to a cloudy pool due to filter now really have a chance to do it's job.
You can fix any and all of this with our help. Your Dad may have to help when the time comes to do the permanent fix as it might take two sets of hands. This will be later when you are ready to close the pool.
For now think over what you think you can do NOW to get those girls in the water. (Shhhh don't tell them but my husband said to let them in the pool and start running around the pool to make the water go in the direction needed to help the water go around the pool and into the skimmer LOL)
ANY input from ANY one will not hurt my feelings! All I want is to get those girls swimming!
Kim
Two ideas:
Kim
