Note* The 12ppm shock level mentioned in the guide is based on an assumed cya level of 30ppm - if your cya differs then your shock/slam level differs- ALWAYS follow the
FC/CYA Levels.
Here’s the deal,
You should generally raise fc to slam level for some reason, not just because it’s Tuesday or whatever. It won’t hurt to do this on some regimented schedule but it’s not always really necessary if adequate fc levels are always maintained.
Here are the reasons to raise fc to slam level in a spa
* elevated cc’s (above .5)
* cloudy or green water
*High bather load/bather waste that will rapidly consume lower fc levels before dosing again.
Most here dose to or near slam level for their cya after using the tub to ensure they have enough fc to oxidize current bather waste & to make it without broaching minimum before their next test/dose/use. YMMV.
That guide is quite old (written 15 yrs ago) & could stand to be redone a little but it’s the best all in one chlorine spa primer we’ve got currently.
About the swg, since it just hangs down into the water instead of all the water flowing through it at some point I stick to the liquid chlorine side of the fc/cya chart.
The swg is mainly there to handle standby chlorination needs. Not heavy bather loads. For those you will still need to dose with liquid chlorine.
I find in my small tub that if I turn the swg up high enough to makeup for all the fc needs when in use then in the idle/stand by time the fc gets too high. Once again YMMV- testing frequently will help you find your happy place.
As I mentioned above, the guide needs a little work over, I thought of coining the term “the dichlor then bleach &/ swg method” but it seems a bit cumbersome & hasn’t quite stuck yet
