Hey all...recently joined the forum but have been lurking for awhile. Read through a lot of the threads including the Pool School and explanations for chemicals etc. Within the last few weeks my family and I put up a new intex AGP with an upgraded pump (3000 gph and SWG). Did the entire initial startup procedure and everything appears to be running fine. The pool is 6400 gallons so I added 160 lbs of salt and let it sit then ran the filter for 24 hours to ensure all salt dissolved etc. I bought the TF-100 kit due to the great recommendations from this site and decided to do a complete test for all chemical balances in the pool and so far this is what I have:
K1000 Test for Chlorine / pH
No chlorine showing or very very light (if at all) and pH for this test appeared to be 7.2
FC = 0.5
CC = 0.0
CH = 100 ppm
TA = Not sure about this test. Directions say add drops to turn to red but no matter how many drops I added it was more of a pink color. So I went with just enough to turn it pink and that was 1 or 2 drops and it turned pink so that would be 2 drops x 10 = 20
CYA = 0? No matter how much solution I put in the container even all the way to the top I saw the black DOT. So I guess this means 0?
K1766 Salt Test
This test was difficult for me to know when it turns to salmon or brick red as the directions state. Somewhere around 17-19 drops of solution and it turned to salmon color and then at 19 or 20 it went to a dark red or even brown. So I guess I will go with 17-19 drops which indicates 3,400 to 3,800 ppm.
pH (with meter) = 6.9
Any assistance you can provide to steer me in the right direction to ensure all my chemical levels are where they need to be would be greatly appreciated.
Thanks!
FC = 0.5
CC = 0.0
CH = 100 ppm
K1766 Salt Test
Thanks!
