Hi. I am new to pool ownership but enjoying TFP. Thank you for all the advice I have an 8K gal FG pool under construction. Equipment: Pentair Intelliflo pump; pentair ichor 30; pentair salt filter; master temp 250; coverstar autocover; dolphin sigma. Pool is in the ground; deck construction underway. I have TF100 test kit. Current water is pretty clear after i did my first slam this week. Todays numbers: FC: 25; CC:1.0; CYA 40; ph 7.8; CH 150; TA 120. salt level 4000. I know the FC is pretty high so I have turned the SGW down to 20% output. Its raining pretty hard and will likely do so all day today. Should I do anything about the low CYA, CH and TA?
