- May 4, 2018
- 65
- Vinyl
- CircuPool RJ-60 Plus
Hi all. New here, loving this site. This is my first season as pool owner (bought house) opened pool to swamp. Been following the "Turning Swamp to Oasis" sticky. I've been doing well I think but my PH seems to have dropped alot and am concerned, so I figured I'd post. Some background first. When I started numbers were
FC=0
CC=0
PH>8.2 (pool store said 8.5)
TA=40
CH=70
CYA<20 (Pool store said 20 but with my test the black dot was crystal clear I assumed there may be 0 due to the Ammonia levels
Ammonia = Approx 6ppm
At the time I tested for Ammonia with a fish tank kit I happen to have because the CYA was so low and I knew the previous owner used Chlorine tabs.
Before I started the SLAM I added 96 oz of 20% Muriatic Acid (It was a product called Klean-Strip Green from Home Depot - they claim that it has 90% less fumes than "standard" MA - as far as I could tell it is straight MA - so not sure what makes it "Green" other than that it is 20% so maybe lower than "Standard"?? I bring it up because its been in the back of my mind that maybe it contained additives that are not good - if anyone knows this product please chime in)
I also added 4 lbs by weight of Leslie's Stabilizer (CYA) since I wasnt sure about the reading and didnt want to raise it too far
I didnt worry about trying to adjust the TA yet (maybe I should have?)
I tested the PH the next day and it was at 7.2. Didnt bother testing CYA because I knew it would take a while to show up.
On 5/7/18 I Startedt the SLAM
As expected, I needed a TON of chlorine to bring the Ammonia to 0 and then I was able to attack the algae.
It has been going along OK. At this point the Pool is a cloudy Blue and I find it easier to maintain the FC SLAM level of 10 ppm but my latest tests show a VERY LOW PH=6.4?? (Taylor test bottoms out at 6.8 so used fish tank kit and got approx 6.4 maybe even lower (hard to tell color).
Current numbers
FC=10
CC=1.0
PH<6.8 (6.4 per fish tank test kit)
TA=30 (this seems to have gone down since starting?)
CYA=17 (I'm assuming 17 - I'm not good at test yet but it seems very close to 20 but not quite there and assuming I was indeed at 0 to begin per pool math it should be 17 based on the 4lbs added)
My questions are:
1) How concerned should I be regarding the low PH
2) Insight as to why it would drop like that? I thought adding all the liquid chlorine would bring it up?
3) Recommended course of action
PS unfortunately, after the initial testing - I've been focusing only on the Chlorine levels and not the PH so I'm not sure how gradual this decrease was
Thanks for the help
Ron
Here are pics from 1st day and now
View attachment 77365View attachment 77366
FC=0
CC=0
TA=40
CH=70
Current numbers
FC=10
CC=1.0
My questions are:
Thanks for the help
Ron
